- 400 Cam Choices
- Casting codes
- 351M/400
- 351m Edelbrock Performer 400 leaking!
- 2v or 4v
- 351M F/S on Ebay (all ya all)
- 351 modified
- 351M head differences
- Aluminum vs Steel Rocker arms
- motor mount question?
- '78 400 Dipstick tube dimensions ?!?!? CRITICAL ! ! ! !
- can i fit a 460 4vcarb and and 460 intake on a 351?
- identifying the carb #
- EGR block off plate
- engine fire!!! hepl!
- Engine code decoding help
- Runs rough at higher RPM
- carb and heads
- Cuts out when hot
- 400-hv oil pump?too much press-vs-too little oil volume-which oil??
- Something to look forward to..
- Low oil pressure - Need detailed instructions for fixin' :)
- Old 400.. Need advice
- The motor that would not die !
- Can anyone help me ID this engine
- Update on my knocking 400M
- timing gears vs Chain
- distributor frozen in block
- 351M repro parts
- 351 c
