- pump to carb fuel line
- Edelbrock 2171Pk
- Fender well exit headers ?
- 351C Operating Temps
- Normal Operating Temp for 351m
- Anyone dealt with AusFordParts?
- Air Pump ? How important is it ?
- where can I find a 351/400M rebuild kit
- What is up with OEM vs poly engine mounts??
- rods
- cam - how much is too much?
- Model "T" timing control option
- Hedders for 77 F250 4x4
- How do you tell which one...
- Oil Pan availability??
- duraspark
- EGR Use
- Water Pump/Thermostat Compatability
- intake question
- Latest engine projects
- Header coatings ?
- Cork vs Rubber Valve Cover Gaskets
- Strange Humming Vibration & Running Rough at Idle
- dropping oil pressure
- 351M mated with a C4?
- Info on 400M - History
- replacing rod/main bearings/front seal/rear main, any help/suggestions welcome
- 400 Cam Advice
- 351M vacuum hose
- 71 distributor Recurve or not?
