- msd advice
- Pulling a 351m/manual
- advancing timing?
- oil dipstick tube
- 400 slight rough idle
- what heads?
- Alternator bracket without air pump mount
- 400 block and oil...
- What other engines use the same distributor as the 400?
- 351m knocking on decelleration
- Hex Key Exhaust Manifold Bolts!?!?
- oil viscosity for 1981 400 (6.6l)
- P/S pump brackets needed
- Ignition Timing on 78 400
- D.U.I. dizzy on a 400
- 600-700 hp for 400
- roller cam ?
- DCR Questions for the brain boys
- roller chain ?
- aussie head questions to bolt on 400
- Help! Small parts needed...
- where can i find a 1973 400
- Intake adapter plates
- 434/ 400 stroker update
- to mill or not to mill
- cam question
- 78 F-150 400 comp cams xe262
- Issues with 1979 F150 4x4
- how do i figure out what size my heads are?
- Which timming chain to get for the 400?
