rear main seal
Old Sep 23, 2002 | 03:18 PM
aj5601's Avatar
aj5601
rear main seal
another quick question, is the rear main seal hard to replace? can i get away with just dropping the tranny and oil pan to fix it?
Andy
Old Sep 24, 2002 | 07:28 PM
79_250RangerLariat's Avatar
79_250RangerLariat
rear main seal
The rear main can be replaced just by dropping the oil pan. While your in there is a good time to check the bearings and timing chain. It's a pretty easy fix.
Good luck!
Old Sep 24, 2002 | 10:20 PM
Torque1st's Avatar
Torque1st
Posting Legend
rear main seal
-And replace the oil pump, clean/replace the pickup, and find out why you don't use silicone gasket sealer.
Old Sep 25, 2002 | 11:44 AM
aj5601's Avatar
aj5601
rear main seal
so you are telling me not to use gasget sealer?
Old Sep 25, 2002 | 06:55 PM
79_250RangerLariat
rear main seal
A little gasket sealer on the pan gasket is alright, just dont' get carried away or sloppy. You don't want to use it on the oil pump gasket!!
Old Sep 25, 2002 | 11:40 PM
Torque1st's Avatar
Torque1st
Posting Legend
rear main seal
I saw a 302 that failed (locked up the oil pump) caused by a bit of permatex form a gasket I estimated to be less than 1/32" dia broke off a pickup tube flange gasket. I use very little gasket sealer. I let the gaskets do their intended function. I do use some grease on some gaskets to get them to release easier. I also use adhesive to retain the gaskets for assy.
For a pan if it is in good shape and you get the flanges real clean you can use a little silicone form a gasket without a gasket at all. It will prevent anyone from messing up your pan seal by tightening the bolts. For small blocks you can get a nice high $$ silicone gasket with metal inserts that works great.
Old Sep 26, 2002 | 12:19 PM
aj5601's Avatar
aj5601
rear main seal
ok, i wouldn't use the sealer on the pump. i don't use much sealer when i do use it cause i too have seen the results of stupid people that do it.
Old Sep 26, 2002 | 02:25 PM
Torque1st's Avatar
Torque1st
Posting Legend
rear main seal
I have used the liquid/paste type pipe dope on thread in type intake tubes. An air leak of any type on the pump intake will destroy the pump over time. Whatever you do, don't use Teflon tape!
Old Sep 26, 2002 | 04:46 PM
Bill_Beyer's Avatar
Bill_Beyer
rear main seal
