351c heads
Old Sep 23, 2002 | 07:31 PM
aj5601's Avatar
aj5601
351c heads
ok, i know i post a lot of questions but i am trying to get into this 351m-400 as much as i can. my new thing is... i plan on turning my 351m into a 400. i want to put on a set of 351c 4v heads. now with doing this, will i have to use the 351c headers? common sence tells me yes, but i would like to know for sure.
Andy
(darn newbie)
Old Sep 23, 2002 | 10:40 PM
Torque1st's Avatar
Torque1st
Posting Legend
351c heads
You know you can find everything you need to know just by using the search function and reading the posts already here. You will learn a lot just by spending some time looking and reading. Just about every possible configuration has been discussed and discussed...
The primary thing you need to know b4 you optimize your engine is the intended application. You build it to the purpose you have in mind. Shazam builds an engine almost the totally opposite way I do. We do have some common techniques but the engine purpose is way different.
Yes, 351C 4V headers are required for 4V heads.
Old Sep 24, 2002 | 01:32 AM
GT40man's Avatar
GT40man
351c heads
and with the 4v heads, you need the spacer plates, and getthe dizzy mod from price motorsports i think.
Old Sep 24, 2002 | 06:16 PM
blu93gt's Avatar
blu93gt
351c heads
...also, because of the 1.1" taller deck, the 351C 4v headers might have some clearance problems. i'm planning the same thing (400 4v) and i'm not going to be surprised if the headers rub somewhere. the 1.1" translates to about 3/4" up and 3/4" out - not a whole helluva lot, but considering how tight some hesders are anyway, it may be enough to cause problems. one thing i've thought about doing is modifying the engine mounts to move the motor down & back - that MIGHT help with header clearance, as well as giving a better front/rear weight balance for better launch at the dragstrip, and lower center of gravity for better handling on the street. i'll just have to try the headers and see how they fit.
what are you building this for?
Old Sep 24, 2002 | 07:46 PM
aj5601's Avatar
aj5601
351c heads
i am building a 351m into a 400, but i want to put 351c heads on it. i want to build a big torque engine in my 79 bronco.
Old Sep 24, 2002 | 10:12 PM
Torque1st's Avatar
Torque1st
Posting Legend
351c heads
If you want some stump pulling torque don't use the 351C 4V heads. Use the Cleveland 2V heads already on your engine. The 4V heads are for high RPM racing only. The 4V's did not perform well at low rpm's for street torque use.
Of course you would know this if you had read all the info available in this forum.
Old Sep 25, 2002 | 11:53 AM
aj5601's Avatar
aj5601
351c heads
ok, so my stock 351m heads are the exact same as the 351c 2v. or should i just go out an buy a set of real 351c 2v heads? and would it be a good idea to mill the heads for a lil more compression? cause i plan on port and polishing them, and if i have some money left over i want bigger intake and exhaust valves put it.
Old Sep 25, 2002 | 03:49 PM
kid vishus's Avatar
kid vishus
351c heads
They are not exactly the same, the exhuast ports are a little different, and unfortunately, the difference is towards the bad side.
However, they are not a bad head. I would keep the heads you have, flat mill around .020-.25 off them, put a 2.10 intake valve in them, a good single piece exhaust valve (standard size), and port them a little (mostly in the bowl area). I would especially pay attention to cleaning the combustion chambers up, they are prone to detonation anyways, and if you can at least polish the chambers, that will help eleviate that a little bit.
Rob Hetzler
93 F150 Lightning, stock w/160k miles
69 mustang, 351c, 9.97 @ 134 mph
99 Pro ET track champion
Old Sep 25, 2002 | 05:45 PM
Brian S's Avatar
Brian S
351c heads
Where can you get a 2.10" intake valve?
Old Sep 26, 2002 | 09:43 AM
kid vishus's Avatar
kid vishus
351c heads
Ferrea makes one. That's what i run. The 2.10 valve is the same price as the rest of the valves in that line, around $12 each, if I remember correctly. It doesnt require much work to open the seat up enough to accomodate that valve, and that means there isnt a lot of extra grinding that needs done in the bowl area, so it's a pretty good compromise bewtween the stock size, and the 4v size.
Old Sep 26, 2002 | 06:57 PM
CrazyFordMan's Avatar
CrazyFordMan
351c heads
Old Sep 27, 2002 | 02:33 AM
Brian S's Avatar
Brian S
351c heads
I couldn't find the 2.1 valve from Ferrea for the 351C. Is it for a different application? Same AOL, stem size and retainer groove? I usually recommend the 460 intake valves for the 2V ports.
Old Sep 27, 2002 | 09:43 AM
kid vishus's Avatar
kid vishus
351c heads
I beleive it was listed for a Yates head or something like that. I hope they havent stopped making them. I need to replace one I ruined in a mild explosion.
It wasnt the high dollar stainless steel line either, it was the next step down. If I had teh heads here I would get the part number for you.
Old Sep 29, 2002 | 01:10 AM
CSMoore's Avatar
CSMoore
351c heads
I HAVE A 400 WITH EARLIER 351C 2V HEADS I'VE JUST PUT TOGETHER.THE GUY THAT DID THE MACHINE WORK ON THE HEADS RECOMMENDED GOING WITH 2.19 INTAKES AND 1.71 EXHAUST I WENT WITH STAINLESS STEEL VALVES FROM COMP CAMS THEY HAVE UNDER CUT STEMS FOR MORE FLOW AND ARE SWIRL POLISHED AND WERE RIGHT AT $200 BUCKS FOR BOTH SETS.I FOUND SOME INFO ON FLOW RATES AT http://www.jason.fletcher.net/tech/flowdata/cleveland.htm LOOKS LIKE A PRETTY GOOD SETUP FOR MY BRONCO STILL HAVE TO REBUILD MY TRANSMISSION BEFORE I GET THE MOTOR UP AND RUNNING.
Old Sep 29, 2002 | 06:41 PM
aj5601's Avatar
aj5601
351c heads
keep me informed on how your engine does when you get it running. you got the same set up i want.
Andy
Bud Mud
Jul 17, 2014 07:15 AM
andy 1979
18
Dec 7, 2010 09:44 PM
dazedandconfused
Apr 27, 2008 01:47 PM
cruz76
Mar 26, 2006 05:40 PM
007bronco
Oct 30, 2004 07:21 PM
