- What are these cast iron headers worth?
- timing adjustment question 390fe
- Oil Pressure Fluctuation
- Motor Suggestions
- large cap candidates
- spring keepers not coming out?
- 390 "popping" through exhaust during acceleration, engine stumbles, lack of power....
- quick question
- Edelbrock Performer or RPM?
- are all flywheels the same?
- 350 or 500cfm for 352??
- 427 Side Oiler Roller Rocker setup needed
- Timing set
- intake manifold
- Oil pump drive shaft fell out
- Used adjustables, what do I look at for wear?
- FE torn down
- FE engine dated
- Numbers on block buy oil pump
- valve seals?
- running without headers?
- tin plate under intake manifold
- 2bbl on 4bbl intake?
- Timing set options ?
- recurving advance on a stock 390
- Block Castings D3TE
- What to do with a 352
- FE Tranny Options
- More piston ?'s
- Valve cover hold-down tabs
