help identifying motor
Old Apr 3, 2015 | 02:49 PM
denf221's Avatar
denf221
Hey everyone just joined thread I just bought a56 fair lane with a 390 in it. The guy I bought it from said it was either a 68 or a 72 motor and he believes it's out of truck on front of block are numbers 45 352. Does not have original intake or carb. What is easiest way to tell exactly what I have here?
Old Apr 3, 2015 | 04:15 PM
arctic y block's Avatar
arctic y block
45 352 tells me it is an FE as all FE's are cast with 352.
For the most part.
As to what CID it is that's another story.
Some one will be along and tell how to pull a spark plug
and measure the stroke. I don't remember the numbers.
Your car had a Y Block, prolly a 292 when new.
Old Apr 3, 2015 | 05:31 PM
banjopicker66's Avatar
banjopicker66
Here are the specs: 3.98 is the stroke for the 410 and 428 engines; 3.78 is the stroke for the 390, 406 and 427 engines and 3.5 is the stroke for the 352 and 360 engines.
Here's the easy way to check the stroke without removing the head. Get a straight 12 inch piece of white electrical house wire or coat hanger wire. Get a magic marker.
Remove a spark plug.
Turn the engine over by hand until the wire is at it's highest point. You might have to rock the engine back and forth a bit to get it to its highest point.
Make a mark on the wire even with the lip on the valve cover. Now rotate the crankshaft 180 degrees, until the wire is at its lowest point. Mark the wire again, at the lip.
Now, measure the distance between the two marks.
Old Apr 3, 2015 | 06:32 PM
denf221's Avatar
denf221
Thanks everyone
Old Apr 3, 2015 | 10:47 PM
85e150's Avatar
85e150
'68 car 390--good, 9.5 or 10.5 CR.
'72 pickup 390, pooch, 8ish CR with sunken pistons from the 410.
You need to find the date code, which is down under the starter:
Ford 352, 390, 406, 427 and 428 Engine Blocks
You will find lots of other info there as well.
Car specs for 1960s glory days of the 390:
http://www.fastfairlane.com/Engines/index-EG.html
Pooch or performer, the 390 is a good motor and you can get a lot out of one with the right parts.
Old Oct 31, 2015 | 10:34 PM
Colo72highboy's Avatar
Colo72highboy
Trying to figure out what motor I have
Hello wondering if anyone knows much about old Mercury motors
Old Oct 31, 2015 | 11:15 PM
85e150's Avatar
85e150
Possibly a 1965 garden variety 390.
If my limited research is correct, '65 was the last year for black long blocks with colored valve covers and air cleaners. The valve cover and air cleaner cover id'd the CID of the motor for easy ID by Ford techs. Fasteners were unpainted, as shown in your pic.
I say '65 as the valve covers have the "newer" pentroof look, vs. the older rounded smoothies. It also has an oil fill and what appears to be the fresh air supply tube or actual PCV connection for the PCV system. It appears to have car manifolds as well, non-performance jobs. (rules out 427, Cougar/Comet--which would be '67/66 & up-- and Canadian pickup motors)
'66 and up, they were all blue even in Mercury, if my "car shopping with dad and opening the hood of every car" memory and other sources are correct.
Other than that, you can't tell externally.
Old Oct 31, 2015 | 11:33 PM
Colo72highboy
I pulled the oil pan and the numbers on the crankshaft read C4AE-B and on the heads they say C4AE 6090G and the tag on the carburetor says c5af ac B 5ca
Old Nov 1, 2015 | 01:48 AM
85e150's Avatar
85e150
Look for a date code near or under the starter.
Could be an all original '65 motor just as it rolled off the line. C4 castings could have been used in '65 and the carb tag is '65 revision. (C5AF)
The carb tag date info (ac B 5ca) doesn't decode. See the decode here--you'll see that "ca" at the end "should be" numbers:
Ford Date Decoding id
Weezer65
May 20, 2007 05:48 PM
oldblues2
Apr 11, 2006 06:11 AM
sean6569
Jun 29, 2004 11:00 PM
boogity24
Jun 15, 2004 06:00 PM
mtstormcars
Jan 2, 2002 05:19 PM
