Without looking it up, I want to say 8.2 or 8.4. They do this with a short piston from the 410. It sits .100 or so down the hole, so shaving the head isn't going to get you much except goofed up gasket sealing and custom push rods.
A compression calculator, millions of which are on line, can tell you the difference once you plug in the specs. You will have to try to figure out about what your new combustion chambers will be.
The 410 piston is a flat top with valve reliefs. You will have to do the math on exactly how far down the hole it is.
guess i forgot to say that my engine is a 68 truck 390, but i have bored it.040 and the pistons sit flush with the deck, it has shaved heads as well(dunno how much though), pistons are dished for the valves
Cutting/shaving/milling and you don't know how much. Now you'll have to possibly have your intake manifold shaved also for proper intake gasket sealing. If not it won't be long you'll be pulling the intake replacing the gaskets.
set your intake on the engine of bolted down heads and Check intake gasket gap clearance. If heads have been shaved more then .020 then intake should be milled to correct square ness fit of gasket.
Orich
Orich
Your also looking at possibly diff. push rods. Those numbers are imp. to know.
