- Torque Converter Talk
- Rookie Resto
- throttle cable
- Hmm, can't get data on my VIN
- Motorcraft Carburetor
- 82 f250 blower motor housing
- Think I located the "Holy Grail" of ZF's
- Steel gear on Dizzy, compatible with Cast gear on Cam?
- Onthe hunt for a ZF 5-sp, will a 2-wheel drive work?
- starter
- What would you value my truck at?
- When changing from TFI to Duraspark, do I have to get a voltage reg?
- 4sp makes noise, press clutch, ..quiet T bering?
- Electrical Issues
- A possible mentor for Dads truck?
- 81 stepside
- Tonneau Cover?
- Suspension question
- Duraspark II Harness
- steel Wheels
- Need help with wiring issue
- Possible 400 swap
- Emissions-air pump
- Look what I found today!
- np435 transfer case options
- Power Window Reliability? (Dad's)
- Transmission gear ratios [comparison]
- Headlight covers
- Gas in crankcase
- help..not doing bad for a girl 85 f150
