Suspension question
Old Feb 5, 2014 | 01:40 AM
drizzie27's Avatar
drizzie27
Suspension question
So this is my first official post, I previously had a '71 F-250. I have since sold it and acquired a '86 F-150.
Now I'm a novice when it comes to suspension so forgive me in advance if I misidentifying a part.
Anyway I noticed the truck has a slight lean on the rear passenger side. I noticed the end of the leaf spring busted a hole in the bed of the truck and the hook that connects to the shackle is disconnected.
Now my question is how to I fix it. Like I said I'm a novice at this so detail would be great and pics even better.
Thanks in advance.
Old Feb 5, 2014 | 05:42 AM
Franklin2's Avatar
Franklin2
Looks like you need #19 in the link below IF you have a 2wd. If you have a 4wd it's basically the same except the springs are wider so it takes a little bit different part.
Truck Parts and Truck Accessories
Old Feb 5, 2014 | 10:48 AM
Kar-Knocker's Avatar
Kar-Knocker
looks like u need a shackle
Old Feb 6, 2014 | 04:11 PM
drizzie27's Avatar
drizzie27
So if I understand correctly, that little "hook" part is supposed to not look like that?
Old Feb 6, 2014 | 04:43 PM
F100Trucker's Avatar
F100Trucker
Looks like it's torn away to me.
Old Feb 6, 2014 | 04:54 PM
Franklin2's Avatar
Franklin2
You got it. That little "hook" part is supposed to be closed in, not spread open like it is. I will warn you, these bolts can be rusted and stuck, so get ready for some beating and banging with a hammer.
Old Feb 6, 2014 | 08:20 PM
drizzie27's Avatar
drizzie27
Awesome thanks a lot. Now how do i relieve the pressure on the leaf springs so i can get it down to connect properly again with a new shackle?
Old Feb 7, 2014 | 12:41 AM
4x484150's Avatar
4x484150
A jack would be your best freind in this case Lift on the frame(as safely as possible) to relieve the pressure on the springs.
Old Feb 7, 2014 | 02:30 AM
drizzie27's Avatar
drizzie27
OK so the bumper hitch would be a good spot then with a wood block to add more support. and since im doing one side i might as well do the other too correct?
Old Feb 7, 2014 | 05:44 AM
Archion's Avatar
Archion
Veteran: Marine Corps
NO. The bumper hitch is not the frame, you never lift a vehicle by the hitch. Frame mounted or otherwise. You need to lift from the frame.
Old Feb 7, 2014 | 05:55 AM
drizzie27's Avatar
drizzie27
Reason I say that is cause I have a different kind of bumper that is welded to the frame. The hitch and bumper is all one piece connected to the frame.
Old Feb 7, 2014 | 08:55 AM
ATS Junior's Avatar
ATS Junior
SPONSOR
Looks like the welds broke on the shackle. Do you have a 2-1/2" spring or 3" wide spring?
-Junior
Old Feb 7, 2014 | 01:31 PM
drizzie27's Avatar
drizzie27
i have the 2.5 inch wide spring.
Heinz5774
Sep 23, 2019 05:34 PM
Eric0486
13
Jan 2, 2018 08:09 PM
capelo
Oct 27, 2013 05:21 PM
leroyinbama
Oct 17, 2012 03:06 AM
IHATERUST
26
Apr 3, 2006 09:56 AM
