Gas in crankcase
Old Feb 3, 2014 | 02:55 AM
oneowner83's Avatar
oneowner83
Gas in crankcase
'83 300 engine. I suspect either the carb (1 bbl) is leaking gas down the intake or the fuel pump diaphram is broken.
It runs sort of bad, but fuel delivery seems ok.
I thought I'd remove the fuel pump and test it for leaking by pouring water down the inlet line, expecting water to dribble down the actuator arm.
Will this work?
Old Feb 3, 2014 | 05:45 PM
Franklin2's Avatar
Franklin2
Why do you think you are getting gas in your oil?
Old Feb 4, 2014 | 02:34 AM
oneowner83's Avatar
oneowner83
Fluid level is much higher than normal and it smells like gas. Should I put a match to it?
Old Feb 4, 2014 | 07:47 AM
KsCop's Avatar
KsCop
Yeah. Do that. Let us know how it works out for you. Press 91, then after you light the match press 1.
LOL
I'd just go ahead and replace the fuel pump. Cheap, easy, and it couldn't hurt. Many times I've seen bad fuel pumps cause the issue. There are other possible causes as well, but fuel pump would be my first thing.
I usually like to do some testing rather than throw parts at things, but in this case, it's cheaper and easier to replace the pump.
But again, that's just me.
Old Feb 4, 2014 | 08:01 AM
oneowner83's Avatar
oneowner83
LOL.. I tend to agree with you. Maybe I'll pull the old pump (knowing I'm going to replace it) and give it the water test.
Old Feb 4, 2014 | 03:10 PM
oneowner83's Avatar
oneowner83
Pulled the fuel pump.
The inlet was still full of gas to the top, so very doubtful the diaphram is bad.
But for $25 I'll replace it with a new one.
I'll jump to the carb now and do my first rebuild.
vidaliaman
Sep 11, 2025 09:37 AM
cannonman
Jul 14, 2010 11:05 AM
abe
16
Jul 3, 2010 09:38 PM
brad1982f250
Nov 20, 2009 05:50 PM
ericeugunep
Aug 24, 2008 07:56 PM
