Think I located the "Holy Grail" of ZF's
Found this at a boneyard.
The model "S 5-42" external slave.
Is this the one that will bolt onto my 84 F-150 302?
https://www.ford-trucks.com/forums/p...ctureid=148846
https://www.ford-trucks.com/forums/p...ctureid=148847
Jim is, as always, right. The one you want has the slave concentric with the input shaft, not on the outside of the case. So you'll see a hydraulic line going into the innards of the bell housing part. I think the small block pattern is the only one done that way, so that should be your key.
AND that it always goes into reverse. Mine apparently has a spot on the reverse synchro that is damaged such that it refuses to go in right there. Move the truck forward a bit, or let it roll back a bit if it will, and it'll go in.
So, why is it a worry? The synchros and bearings are about $250 for the parts alone and the work will be ~$400 to replace them. I paid $500 for my ZF and a transfer case.
You guys are "righter" than me.. Oh well I guess I keep looking, Must keep in the grey matter "internal slave cylinder AND Windsor block pattern required" (for me)
So for clarification there are two ZF S 5-42's, and two 47's???
One big block (external slave) and a small block, (internal slave?)
details, details, always in the details.. Good thing I asked you guys, there would be an incredible amount of "Suck" value if I bought this one and tried to line it up to the motor.
Wondering if there is a way to copy the Windsor flange and have the bolt pattern with me so I can line it up on a potential donor. Anyone ever made a copy of the flange the bellhousing mates to?
