- Oil pressure problem
- Rebuild Carb
- 4-speed swap
- Please help restify my '85 F-150!
- 1981 Ford F-100 302 Engine $$ ??
- 2 Cylinders missing
- f150 86 302 keeps dieing when warm
- Help with brake pedal air noise..
- no power to ignition box
- Rear end ratio id???
- Is it possible?
- no turn signal
- 1981 F100 engine swap
- 4x4 vs. 4x2 frames
- 302 Block Information
- Heater Core Replacement on '85 F150 Without A/C
- How much should the idle vary?
- lights
- 86 f150 302 can I get rid of fuel injection and emmissions and just stick a carb onit
- truck cab needed
- Door and seat interchange
- no spark
- Steering Box?
- Conversion check list, help appreciated.
- Torque specs
- 1985 f150 gas problems
- 1983 F250 runs rough cold
- 100 amp alternator pulgin
- Swapping Rotors to new 6 lug
- Factory Digital Clock question
