lights
Old Oct 23, 2004 | 08:56 PM
caine95's Avatar
caine95
Unhappy lights
I have a 1980 ford f-100 with a 302 in it. all of my lights are very dim, the
brake lights won't lightup unless the light switch is off & even then they're
dim. When ever I use the turn signal the door chime sounds & my clock
blinks. Can someone please HELP, HELP, HELP me ???
Old Oct 24, 2004 | 12:32 AM
Lee Lichterman's Avatar
Lee Lichterman
When the engine is running, how many volts do you have at the battery? You should have at least 14.
Try adding a good ground wire from your engine block to your chassis.
You either aren't getting enough power from your alternator or have a bad grounding problem. With it being on so many different circuits, I suspect it is a grounding problem.
Good Luck,
Lee
