Door and seat interchange
Old Oct 23, 2004 | 06:25 PM
cb3phace's Avatar
cb3phace
Question Door and seat interchange
I'd like to replace my driver side door and don't know if the 80-86 Bronco or Van door would fit. Same thing for 87 and newer do they fit, what year does the interchangeability end for my 1980 F100 ?
Old Oct 23, 2004 | 06:31 PM
TUFFY's Avatar
TUFFY
80-86 truck or bronco full size For the doors.For the seat 80-86 direct bolt in but if you dont mind doing a little fab work you can put just about anything in there.
Old Oct 23, 2004 | 06:41 PM
cb3phace's Avatar
cb3phace
Thanks Tuffy. I know the 87+ doors look close, are you sure they dont fit?
Old Oct 23, 2004 | 06:44 PM
TUFFY's Avatar
TUFFY
No I'm not sure they might bolt up but I think the body lines might be a little different.
Old Oct 23, 2004 | 08:46 PM
mustange70's Avatar
mustange70
The doors will fit, and the body lines i'm pretty sure will line up. Any bench seat from 80-96 (96-97 F-250-F350 as well) will bolt tight in (bronco and F-150-F350), And if your want buckets from the same years fit but new holes must be drilled for the extra holes.
