302 Block Information
Old Oct 24, 2004 | 12:30 AM
Gearhed01's Avatar
Gearhed01
I have a '84 F-150 with a 302 that I am in the process of getting back on the road. I need to find a replacement block for mine and didn't know which year models will interchange with mine. Will later model roller cam blocks work? Is there any difference in deck heights? Thanks in advance for any help.
Old Oct 24, 2004 | 06:33 PM
alcan60283's Avatar
alcan60283
All the 302 blocks are pretty much the same externally. The dimensions are all the same and so are the deck heights. The only differences would be things like EFI and roller cam blocks, etc. ITs all pretty much internal differences. The blocks are all the same.
Old Oct 24, 2004 | 09:54 PM
Gearhed01's Avatar
Gearhed01
Thanks for the information. I was just curious if you had to do anything special since the '85 and up block had the taller lifter bosses for the roller lifters in those motors. I just need to know if I could install a stock replacement hydraulic cam in a block intended for a roller cam. Again, thanks for the help.
BRay09
Mar 3, 2014 09:34 AM
boonslick
Electrical Systems/Wiring
Dec 5, 2013 02:53 PM
WoomaHodal
Jul 16, 2006 02:38 AM
Huntersbo
Mar 23, 2006 12:37 AM
Dipstick
Dec 20, 2005 03:24 PM
