i have a 1985 ford pick-up that has been sitting for 6 years .well we went out to mess with it and it fired right up with a fresh battery and good gas
i think i want to restore the truck but the cab is rusted
anyone know where you can get a cab (is it even called a cab?)
and if you buy the cab do you have to get one with a title
im not sure how the vin number on the dash comes out
thanks any info will help the beast out of the woods
any cab from 80 to 96 will work, but 87 and newer would need to rewired using the harness from your current cab you have, that is unless your truck is efi.
so if i get another cab later then the 85 will the front clip work with it also
like my fenders ,doors,hood,etc
also are beds like the cabs for the same years
wow thats cool to know thank you very much................pete
How bad is the cab? I thought mine was going to be rusted beyond repair but if your good with a welder it might be cheaper to fix it, just a thought. Check out my before and after pictures in my gallery. I believe that your current fenders, hood, and doors will fit a later cab. As for the beds, any 1980 to 1996 bed will bolt up the only difference is that 1987 to 1996 have different shaped body lines over the wheel wells.
wow you did great work on that truck mine is not as bad but most of my rust is on the floor of the cab and the bed maybe i should buy me a cheap welder ........is there such a thing lol
