- tired pump and leaky return lines?
- Adding coolant
- Fuel backcheck valve
- Lots of metal in oil......
- Aux battery setup.. which type of isolator?
- Tranny Cooler
- I Wanna Build A 6.9!
- Fuel Filters Reviews Comparisons Tests?
- first mileage reports after zf5 swap/.
- Front & Rear Sway Bar Bushings
- Bah WaterPump..
- 1994 7.3 Turbo IDI difficulty starting- smokes briefly
- Crackling noise
- strait axle swap into my 94 f250 from 85f350 questions
- Still working on 1994 turbo idi
- can u use newer style glow plug controller on 86 6.9
- My first idi
- Fueling Issues Solved
- Need feedback on My 86 6.9 Compression test??????????
- 89 7.3 op sending unit location
- 7.3 IDI rough start
- Coolant question-distilled water for test fire OK?
- Power or lack thereof...
- Water in oil
- 1986 f250 auto trans hard/no shift 1st to 2
- 94 7.3 IDI Idler pulley
- here i am again!hard start when hot,not wait to start indicator?
- ZF5 Slipping like auto
- 1978 ford f150 7.3 idi swap HELP!!!!
- Anyone running LuK parts
