Fueling Issues Solved
Old Jun 26, 2012 | 10:57 PM
swampbear's Avatar
swampbear
Lightbulb Fueling Issues Solved
As we all know, Most of the fuel necks are to small to get fuel anywheres, or off-road for that matter. Well I dug into it thinking, Ah shouldn't be that difficult, Pop it out and punch it out and pop it together. Well there is more to it, Not difficult, But have an hour to play with.
I also found the issue with the "sensitive fillups" where the pump keeps kicking off becuase of placement issues in the filler tube, There are 2 in them. The "main fill" and the outer "overfill/protector" tube, I removed the inner filler tube, And have filled up 3 times now trying to make it spray, kick or leak, and its golden.
I figured to post it on here incase your running into the filler neck diameter problems or fill up sensitivity, that its semi quick and easy!
Old Jun 27, 2012 | 01:02 AM
91dirtydiesel's Avatar
91dirtydiesel
Mine fills to quick and spills out before pump shuts off....only happened 3 times so far but still shouldn't happen...
Old Jun 27, 2012 | 04:09 PM
Aune163rd's Avatar
Aune163rd
I removed the overflow and still had filler problems, never could figure out why the 1990 had so many problems filling up, both tanks do that and it drives me nuts.
Old Jun 30, 2012 | 12:15 AM
Greg5OH's Avatar
Greg5OH
i keep thr nozzle out slightly, still shuts off before overflow(has bever iverflowed)
bubbar1950
2004 - 2008 F150
Jun 25, 2014 04:19 PM
95schauf
Feb 10, 2013 10:00 AM
JD_F250
Mar 29, 2010 02:01 AM
el cheapo
1983 - 2012 Ranger & B-Series
Oct 7, 2009 10:58 PM
hotrodmerc
Bronco II
Jan 13, 2004 12:12 AM
