- 2005-2007 OEM headlights ( where to find ? )
- Turbo acting odd
- Light Throttle Flutter
- A/C issues?
- Help ford 6.0
- Another 04 No Start
- Loose Steering
- Mystery squel
- Need New CAC boots...need opinions
- Boost drops to 0 after tranny hit overdrive
- Ficm voltage is low while glow plugs cycle.
- CAC boot torque specs
- No crank after running a while
- 2005 LPOP issue?
- Rough running until up to operating temperature
- 5R110 differences
- Need help
- unsure about obd11 p1335 05 f250 sd diesel
- Heatshield & IPR
- coolant not 50/50
- 100k maintenance/service present
- No turbo until 20 minutes into the ride
- Head Gasket Scare
- Helping a friend with an issue
- up pipe concern on egr delete...and heat shield pics?
- BT349 or LF3346 for BPD systems....any takers?
- Harpoon w/Bed Off
- 5R110 Transmission Failure
- 05 f250 brake controller
- Lubricants for diff’s and xfer case
