- Door locks
- My 6.0 kas a mind of it's own
- Things to check, clean or replace when you go over 100k
- Going to the dragstrip this Sunday...
- 03 6.0
- Water/meth questions
- 6.0 compared to duramax
- 2005 SCMT (tuner) on a 2006 - will it work?
- Flash Question
- How are the 2007 6.0's?
- Can they tell if it's been chipped w/edge?
- Slight surging???
- dp tuner
- voltage and current out put for Rv charging
- Turbo & injector upgraded (disapointment)
- Help New X3 Problems
- EGR Cooler Bypass Kit Install
- EGR and mileage
- white smoke
- What would you do?
- OASIS report please!
- Permatex copper seal on head gasket
- intercooler piping coming off
- Broken FUEL guage
- ZF 6sp gear rattle
- coolant leak
- Trouble Removing Turbo
- Oil Temp Sender
- Simple Newb Question about boost
- Will a 6.0 work for me?
