- Replacement of egr cooler and oil cooler
- Are there any seals on a 6.0 that may leak coolant into engine oil?
- 6.0 sounds like semi-truck on acceleration
- IPR Screen and Oil/Coolant Questions
- Long Grade 220ECT
- Just another chirping 6.0
- Off idle rpm cut out
- Boost Leak from EGR Valve
- 6.0 injector service
- 2004 PSD files when warm
- New fuel pump but not fuel in top filter housing
- Glowshift 3 in 1 gauge
- Electrical upgrade
- Oil leak help
- E450 - black, then white smoke, no power
- '06 6.0 Starts hard/falls on face
- $^**&^$=$_<<*$#×$_<_
- Need opinions on cooling
- Found Coolant in my engine oil. How?
- what happens at 123-ish degrees Oil Temp? Resolved!
- FICM Question
- 7.3 looking at a 6.0 need some help!
- Looking for new heads and other parts.
- Ran out of fuel. Now my IPR% is higher then normal
- Electrical issues.
- No Oil Pressure, starts and runs fine?
- No Crank, No OBD communication
- Installing EGR Delete
- AFE Oil Filter?
- What should I be looking for when buying a 6.0??
