- source for Ford eot/ect test procedure?
- cummins conversions in Alberta?? Who's doing them?
- OEM head gaskets
- Cold start issues w/ sick glow plug warm-up sound
- Oil cooler issues, opinions needed...
- URGGG Truck want start.....
- custom tunes???
- motor coughing feels like it's going to die
- Why The Bubbles?
- Lift kits
- External oil filter system
- Stuck in Injector purgatory, Help!
- Black Greasy substance on sides of Coolant tank.
- front axel bearings
- oil cooler ??
- Fuse Location 2006 Model Year
- Mechanic on SF Bay Area Peninsula
- Building a bad a$$ 6.0l
- Where is my voltage regulator?
- finally changed my batteries...
- Fuel gauge all over the place
- low oil pressure relief valve
- Trans fluid? Radiator, water pump change out
- Kansas City 6.0 members
- Well had to break down and get alternator
- FOUND!! 07 6.0L with 1,000 miles on it, What would you do?
- Help with oil cooler replacement ???
- At times , will not start
- EBC Brakes - Who's Gottem?
- Is my 6.0 a time bomb ?
