05 f250 brake controller
I’m having some trouble with my brake controller, ever since I bought the truck I’ve had problems with the brake controller check trailer light coming on and off pretty frequently even when I’m not towing anything. It seems to say check trailer everytime I go over a bump.
last weekend I hooked up a trailer and I had to disconnected the brake wire on the trailer harness because the controller kept saying check trailer and the brakes were locking up. Any ideas on what it could be? A short behind the controller in the dash maybe?
As far as pulling from a junk it's hit or miss if it's good or bad. I chose to buy a new one on eBay for around $175. This was before Ed started providing brake controller repair services. I just didn't want to have to think about it down the road if the unit would work or not. Good luck.
If you have Forscan you can monitor the TBC for inputs and outputs. Here's a screen shot.
I wasn’t getting power to the running lights either so unless you have to be going 15 mph for it to get power to the running lights as well, then I have a problem. I’m not totally sure on this but is the check trailer light supposed to go on if I apply the brakes on the brake controller and I don’t have a trailer hooked up?
I would take a closer look at the harness and plug. If you lose continuity with the electric trailer brakes or lose ground it will give you the check trailer message. If you have no parking lights at the plug then you have a harness or a plug issue. Unplug the harness at the back of the 7way plug and inspect it. Then further up the harness is another plug, check it. There is also a ground wire to the chassis, make sure its attached. Of course check fuses first.
Shovelheadrob
Fifth Wheel & Gooseneck RV Towing
10-18-2016 09:38 AM
zxwut?
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
02-20-2009 11:13 PM
FordTrucksKickGM
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
02-03-2008 11:10 PM
