Help ford 6.0
Old Jul 25, 2018 | 06:59 PM
Jarrett Spencer's Avatar
Jarrett Spencer
Help ford 6.0
I have an 04 Ford F-250 6.0 and I just had the motor redone from a blown head gasket got fire ringed heads new headgaskets arp headstuds and egr delete and I’m still leaking some antifreeze out of my degas bottle need help only have the truck back for two months (also have a sct tuner with innovative diesel tunes)
Old Jul 25, 2018 | 07:44 PM
Maxium4x4's Avatar
Maxium4x4
Well how full is the degas bottle for starters? Old cap perhaps, cracked bottle maybe?
Welcome to FTE
Old Jul 26, 2018 | 05:32 PM
Jarrett Spencer
Welcome to FTE
I have put a new degas bottle on it quit leaking for a little bit then started again
Old Jul 26, 2018 | 06:58 PM
Maxium4x4's Avatar
Maxium4x4
Describe leaking and how full is the bottle?
Old Jul 26, 2018 | 10:23 PM
87crewdually's Avatar
87crewdually
Plumb in a pressure gauge and see if it's building pressure. This test is well documented here and youtube. The reservoir should be in the lower half.
After the engine is warmed up, open the cap and vent any pressure then tighten the cap again. Go for a drive at WOT and see if the gauge spikes up to 15 or so. If it is rapidly then you have a combustion leak into the coolant system. If you're EGR cooler deleted then I'd suspect head gaskets as long as the coolant isn't contaminated with fuel or oil.
Jarrett Spencer
Jul 24, 2018 09:44 PM
Muddy008
Apr 4, 2018 05:53 PM
9905
Feb 6, 2010 07:41 AM
heartnurse73
Dec 26, 2008 06:10 PM
FullThrottleRacing
Nov 6, 2007 01:37 PM
