- RPM Guage is stuck at 2000...
- painted mirrors???
- How do I rebuild a turbo- po299 code
- Loss of power (intermittent but getting worse))
- I Do Believe its Turbo Time
- EGR delete and smog testing.
- Temp #'s
- Opti-Lube XPD
- Unplugging EGR
- Need help, OBD code P0460
- It pays to bring it to a trained Diesel tech mechanic
- New 2007 F250
- Tell me what you think about the 6r
- A/C Clutch fell apart Literally
- Back-up Light Install
- Mileage
- Fuel in Water, how to drain?
- cold starting issues
- Egr/Cooler Delete. ARP's, 4" Turbo back + SCT update.
- Hollowed out cat will it still pass emissions?
- Kumho Road Ventures M/T or Toyo Open Country M/T
- hesitation at take off-6.0 psd
- TSB 09-24-3 Should I Get it??
- Coolant Filter at 85k Miles?
- Another engine swap question for the Guru's
- Changed coolant filter. Interesting find.
- Diesel fuel in coolant woas. 6.0 <3
- Cold start improvement
- Totaled my F350
- Think my starter is going out.. *UPDATE*
