- Turbo mounting bolts won't budge!
- Coolant loss - can't find any leaks - not puking - holds pressure
- New batteries - charge for 20 minutes then nothing again
- Crazy MAP readings
- Clunky feeling underneath "transmission"
- Ford F250 SD having Engine Issues
- truck starts but won't stay running
- glow plug problem
- 6.0 tuners
- Never fails
- Glow Plug Codes Set
- Wipers randomly activating / wiring in steering column
- 6.0 no start/ knock condition
- Injector replacment
- anyone have cylinder heads for sale?
- Adios 6.0
- Advice on 4" turbo back
- 6.0L Lower Fuel Filter Change problem
- 5 speed trans went tinky, tinky, BANG! today....
- icp sensor questions on a 2003.5
- INFAMOUS 6.0 CRANK NO START EVEN AFTER REPLACING HPOP ETC>>>> HELP
- Proud papa moment
- Hit 250,000 miles today
- To keep 2006 f250 or not 6.0L
- FICM sync/no sync when does it switch
- Turbo whining?
- 2005 6.0 speedo not working, no power
- Pinion seal replacement
- Nose up or nose down for fuel filter change...
- injector cup replace
