- used 6.0 PS..what to do right off the bat to make it bulletproof?
- Looking into getting first truck
- Cold start - great one day and bad the next
- should i go to a 6.0 from a 7.3?????
- just did a Oil Change with Rotella
- F350 and Code PO402
- Fuel Pressure Test 6.0
- Engine Oil???
- Alternator recommendation
- Help! 6.0 problems...
- Did we ever get an answer to...
- Tire Size and Gear Ratio
- Turbo oil drain o-rings
- Trying to find a leveling kit!!04 6.0
- injector and turbo compatability
- gold coolant
- Scangauge ll in very early build 6.0 high EOT - ECT deltas
- Will a 05 auto trans fit in my early 04?
- Gauges and Tunes
- Charging the coolant under a vacuum
- Plastic radiator repair
- Truck won't start
- Well now comes electrical issues
- what oil is what
- Wired up high idle mod, threw switch, and...nothing happened.
- Sold my truck.....have parts someone could use..
- 04 F350 6.0 or 05 F350 6.0
- Truck died out while driving
- Need help with OEM oil filter housing.
- Truck Died. Loss of power..Fuel pump?
