A/C issues?
Old Jul 25, 2018 | 11:53 PM
Vinford's Avatar
Vinford
A/C issues?
Tried recharging my A/C , it didnt work , still blows hot air.
Where to start trouble shooting?
Old Jul 26, 2018 | 08:25 AM
TooManyToys.'s Avatar
TooManyToys.
Did you confirm the pulley clutch engages?
Old Jul 26, 2018 | 10:27 PM
Vinford's Avatar
Vinford
I listened for it and didnt hear it
Old Jul 27, 2018 | 07:31 PM
87crewdually's Avatar
87crewdually
Start with manifold gauges to see if there is enough static pressure to activate the switch to kick in the clutch.
If it is getting power to the clutch then an enlarged from wear air gap can cause the clutch to not engage. If the gap is too large, you can remove the center bolt and clutch disc. After removal of just the disk, inside there will be a shim that you can remove to lessen the gap. Remove shim, reassemble, and recheck the gap. Retest.
Clutch coils can go bad but usually at that point I recommend replacing the compressor, drier, and orifice tube. Also keep in mind wiring issues and pressure switches (high & low) can also go bad.
Old Jul 29, 2018 | 07:23 AM
DSMMH's Avatar
DSMMH
The reason your charge did not help; there is air in the system. Air is the enemy of an AC system’s efficiency. You need to hook up a vacuum pump through a set of AC gauges to the low pressure side and pull a vacuum for about 30 minutes. Shut the gauge valve and turn off the vacuum pump. Let set for another 30 minutes to see if you loose any vacuum. You probably will. Got to fix the leak before charging. You will need to take to a shop so they can put dye in the system to find the leak. If you don’t, you are throwing money away. Probably cost about $150-$200 to charge, depending how much R134a you need. I just had my X done. I have to get it done every 3-4 years. I have a very small leak around the compressor shaft seal.
Ed
hornfan
Oct 26, 2021 07:19 PM
skidooman1990
Sep 4, 2018 09:24 AM
1L243
Jun 13, 2015 12:11 AM
whanlon
May 26, 2006 05:19 PM
Pocketchange5
1997 - 2003 F150
Sep 23, 2005 07:54 AM
