- fog light wiring
- Torque specs for Oil filter adapter Housing
- Looking for a couple trucks...
- FICM Repair: Repour liquid plastic over circuit board ?
- Help with water separator 2005
- Auto Enginuity
- ARP Studs and Bulletproof egr cooler
- need some help on a couple of part numbers.
- ICP Pigtail wiring HELP!
- High ECT/EOT after flush and thermostate
- SCT tuning safely
- Removal of stand pipe in oil filter housing ??
- Updatefor Blade35
- Oil change today - A few lessons learned
- 6.0 L noise
- EGR cooler question.
- Odd problem...hittin' on 4
- MINIBIKE PICS FOR BENNY
- High mileage overhaul
- 04 f-550 6.0 lossing coolant out of recovery tank
- Me VS Turbo
- egr cooler leaking, can i pinch the coolant inlet
- codes
- no power to scanner
- Fram oil filter change((( new pics loaded))
- First California Smog Check comming up
- Fuel leak Found and fixed
- Ac question not cooling
- Hack Mechanic Install (not) of MBRP
- FICM symptoms/tests other than 48V check
