- 6.0 mechanic in Clovis CA area?
- Help with a part number
- No power off idle to 2000 rpm
- Advice needed "Injector circuit low - cylinder 4
- Coolant Filter
- Battle of the mechanics - who is right?
- Coolant flush today
- parts engine
- Mobil Delvac 1 5W40 - UOA
- Should I just remove Rocker Carrier or entire Head?
- Aluminum rocker box
- Some Diagnostics help please!
- IPR command via IDS
- Blue Diamond Rep showed up at the shop.
- thoughts on vegetable oil conversion?
- 6.0 build update
- [Video] Replacing that stupid plastic intercooler tube.
- Cranking issue
- Limp mode with trailer - underboost code
- Rocker Carrier Torque Spec PLEASE
- Excessive bounce/hop while driving
- Typical 6.0 Issues but working through them.
- Stock air filter ? or cold box high flow ?
- Cleaning turbo, what type of anti seize
- Ranch hand question
- 6.0 L rough running cold starts
- Kinda cool
- Starter question
- Replaced injector still getting Contribution and misfire codes
- Strange noise at low rpm/boost
