- scangauge II
- AE trying to fool it to find a miss
- 2006 F350 w/psd...reliability?
- Replacing damaged FICM connectors...A HOW-TO with pics
- Replaced heads, water pump, now its hard to start puffs white/black smoke, and wont warm up.
- low/soft brake pedal
- Weekend project v. thanks to everybody on FTE!!
- aftermarket fuel lids? which one?
- Oil cooler and bullet proof EGR cooler failure in 2k miles!?!
- head studds
- Those with coolant filters!!! Chaffing!
- Scangauge "EGR Valve Position Measured"
- Will a 2004 F350SD 4WD Trans go in a 2003 F2504WD both 6.0L
- Success Story
- Exhaust color
- ScangageII XGage ?
- SCT Livewire
- rear diff popping - binding bad
- Alternator died and I get ABS light
- Truck Dead AGAIN!! AHHH
- my truck rpm drop and the truck blows smoke for 5-9 seconds some times.
- Should I trust this scan gauge??
- ECT and EOT temps very low?
- REPS!!!
- Ok guys an egr code question
- Leaking injectors home check or something else?
- 03 6.0 ???'s
- Edge's pressure sensor install?
- update time to put it all back together!!
- Delete thread please
