- 100k maintenance/service present
- No turbo until 20 minutes into the ride
- Head Gasket Scare
- Helping a friend with an issue
- up pipe concern on egr delete...and heat shield pics?
- BT349 or LF3346 for BPD systems....any takers?
- Harpoon w/Bed Off
- 5R110 Transmission Failure
- 05 f250 brake controller
- Lubricants for diff’s and xfer case
- Long cold start/no start hot. Double checking my findings.
- Cold air elbow at turbo has melted through
- SCT livewire TS+ what do I do with my egr
- What Transmission to Get?
- HELP! Driving truck switched into 4x4 low
- OBD Software
- 2003 SD 6.0 another No Start
- oil in coolant - AGAIN
- 2006 6.0 High engine oil temp issue
- Thoughts on tuning in my case?
- Transmision won't shift into 4th gear on brand new rebuilt tranny
- Wiper Blade deal
- Transmission overheating but all other temps fine.
- Some weird electrical stuff going on
- Engine Work: SDS or ????
- Jump in temp differential after head gaskets
- Dummy plugs and standpipe replacement.
- 04 f250 start and dies few seconds later
- IPR Cover
- Icp psi ?
