Head casting #
Old Jan 18, 2001 | 10:15 PM
xaviar's Avatar
xaviar
Head casting #
I have a pair of 429 early casting heads and can't seem to find out what they are. Can anyone decode this head
C9AE-A
I had thought it was off a Mercury Montclair because all ford castings were D0AE or later castings. Mercury's were of C9 vintage.
From what I've found so far it could be off a Mercury. Head has Closed chamber, screw in studs and guide plates.
Could this be a interceptor head? Would like to find out if anyone knows.
Thanks,
Xaviar
Old Jan 19, 2001 | 05:41 AM
cobrajet's Avatar
cobrajet
Head casting #
hey Xaviar, how is everything going? what you have is a plain jane pair of 429 passenger car heads. C9AE-A. C = 1960's ,,, 9=the year 1969,, A= the model code and A stand for all full size fords,, E= represents the engine division. sorry these are not police heads. these could have come off old thunderbirds! they are a good pair of heads the comp. ratio is 10.5:1. hope this helps ya out. later....
Old Jan 19, 2001 | 09:27 AM
xaviar's Avatar
xaviar
Head casting #
Howdy CJ, Everything is fine here. Yeah, I knew they were 69 heads, was hopeing for a diamond in the rough........LOL. Well, at least they're a good set to use. I knew they were different. I've never seen a set of 429/460 with a substantial quenched area around the plug.
Thanks for the info
Xaviar
Old Jan 19, 2001 | 11:32 AM
Chuck P.'s Avatar
Chuck P.
Head casting #
Just a bit more for you, the chamber size is 75.8cc, valves are 2.08 and 1.66, ports sizes are 2.18 x 1.87 and 1.99 x 1.30. Can be upgraded to the CJ size valves and a little port work on the exhaust side mostly with matching on intake side will really help these even if you don't put in the larger valves.
Old Jan 21, 2001 | 10:07 PM
bb79ranch's Avatar
bb79ranch
Head casting #
trozei
40
Sep 12, 2020 09:22 PM
logan.hawes
Jun 24, 2010 03:43 PM
nofortunateson
Nov 30, 2007 09:38 AM
katman469
May 18, 2006 02:42 PM
rustygreen76ford
Apr 10, 2004 11:34 PM
