heads
Old Nov 17, 2002 | 11:41 AM
erikl85's Avatar
erikl85
heads
Old Nov 17, 2002 | 11:59 AM
wsam050547's Avatar
wsam050547
heads
I need to know where to find some informatiom. I.m getting ready to rebuid the 460 in my 66 f-100 the engine is a 74 lincon with 8.0 to 1 compression heads number DOVE-A2A I think these are 84 cc heads.They have pedestal rocker arms. I have a good set of early model heads model number DOVE-C I,m told these are 70 model heads.These heads have stud rocker arms.Does anyone know what cc both sets of these heads are or where I can find this information? Sam in Memphis
Old Nov 17, 2002 | 01:43 PM
gray79f250's Avatar
gray79f250
heads
I think the first set of heads may actually be D3VE-A2A the 3 can look like a 0. These are around 93-96 cc I beleive and the D0VE-C are around 73-76 cc. The DOVE heads should make about 9.5 to 1 compresion on a 74 lincoln 460 with dished pistons. My cc numbers may be a little off but I know they are very close. If you look through some other posts on these heads you can find the exact numbers. Good Luck Andy
