Camshaft opinion
Old Nov 16, 2002 | 06:10 PM
bigxd's Avatar
bigxd
Camshaft opinion
Hi Guys,
Im starting to prepare for a rebuild of my 71 460 and have a question regarding the camshaft. The profile I'm currently looking at has the following specs:
Intake Open 33
Intake Close 69
Intake Adv. Duration 282 - or 234 @.050"
Exhaust Open 74
Exhaust Close 38
Exhaust Adv. Duration 292 - or 240 @.050"
108 Lobe Center
Lift at Lobe .085"
Lift at Valve .547
Suggested comp 10:1
I like this cam because it is longer on the exhaust, but im a little worried about the lobe centre angle. With 108 it might be a little tight for a truck? (F150 SWB)
Anyone know what the characteristics of this cam will be like?
Am I gonna need some serious porting on the heads or will I be able to get away with just some smog bump removal?
Im currently running a C6 and 3.00 at the diff. Would I need to consider a stall converter or maybe dropping the ratio to say 3.55 or even higher?
Any clues on what vacuum will be like? (poor/good?)
Any help would be greatly appreciated.
Thanks,
Steve
Old Nov 17, 2002 | 08:25 AM
DeenHylton's Avatar
DeenHylton
Camshaft opinion
That cam will be way too big for your truck unless you intend to use it for racing. Looking at Summits generic cam guide they state your power band would be 3000-6500 rpm. They also recommend a stall converter 2000 RPM above stock which would put you around 3000-3200 stall. I'd go further than that and say you'd also need a 3:73 to 4:11 gear depending how tall your tires would be, headers, dual exhaust, aftermarket ignition, 800 CFM and up carb.
If your truck is used mainly for street use and off road 4-wheeling get something similar to the Comp Cams 268 series or the CompXtreme series. Other cam MFGs. have similar grinds
Old Nov 17, 2002 | 01:52 PM
gray79f250's Avatar
gray79f250
Camshaft opinion
That cam would need more gear and convertor for sure. You should try to get a cam with split duration and lift to help with the small exhaust. I would say porting for sure. Be sure to change the springs also if you go over 500 lift with stock springs you will get coil bind and bend the pushrods. I bought a rebuilt 429 for $300 because someone used stock springs and a big cam. They couldnt get it started lol my lucky day.
Old Nov 18, 2002 | 10:42 AM
georgedavila's Avatar
georgedavila
Camshaft opinion
As others have said, that cam is way too big for stock heads. Even removing the smog bumps won't be enough for them to flow that lift. .520 is about max lift with the smog bumps removed.
Old Nov 18, 2002 | 09:47 PM
LxMan1's Avatar
LxMan1
Camshaft opinion
Use the CompCams 268h. I love it. Use a good double roller timing set and put on matching valve springs any time you install a larger camshaft!!
Jimmy
Old Nov 19, 2002 | 01:24 AM
merc460's Avatar
merc460
Camshaft opinion
Old Nov 19, 2002 | 03:57 AM
bigxd's Avatar
bigxd
Camshaft opinion
What kind of horsepower / torque can I expect from the CompCams 268h? (after I port the smog bumps etc) Ive seen a lot mentioned about this and the 272h.
Has anyone had experience with oversizing the exhaust valve? I was reading somewhere that a 1.8 - 1.9" valve works great as it ups the valve/port ratio and the inlet/exhaust ratio. They say you still need to port it, but really only to remove the bumps and help with the bowl shaping. No need to go wild with the die grinder. Using the smaller valve requires a lot more port work because of the valve/port ratio.
Does any of this make sense?
I want my old beast to COME ALIVE!
Thanks in advance,
Steve
71' 460
Holley 850 Dbl Pumper
Stock Heads D3VE-A2A's
Stock Manifold
Stock everything!
2.5" Stainless X-pipe and dual 2.5" high flow mufflers
31x10.5x15 Dunlops
3.00:1 rear
C6 with shift kit
62mph in 1st and still pullin!
Old Nov 19, 2002 | 08:32 PM
chilly390's Avatar
chilly390
Camshaft opinion
Simply going with a larger valve doesn't automatically improve flow, you have to look at the throat diameter in the port. Plus, if you look at it, the bigger the valve the more the air has to turn to move around the valve. Not saying it won't help, just that there's a limit. Some good info on this site...
www.reincarnation-automotive.com
abear1233
19
Nov 30, 2016 07:18 AM
F-250 restorer
Aug 27, 2015 07:41 PM
drexer13
Oct 21, 2013 08:53 PM
fordflaresides
Dec 7, 2005 09:48 PM
EXOPAR
Jan 17, 2003 11:58 AM
