460ford site help
Old Aug 9, 2008 | 10:55 PM
plastikosmd's Avatar
plastikosmd
460ford site help
can someone pm me chilly or another admin email address? I have an account..but the admin never verified it...so i cant log on..and if i try to create a new account...says that email is being used by another member...(me)....sigh..one endless loop..and of course you cant email the admin like they want you to...cause ya cant friggin log in....grumble
thanks
Old Aug 9, 2008 | 11:29 PM
wyazel1's Avatar
wyazel1
I have the same exact problem over there. I created a new account using another email address and it said an admin would have to approve the new account before I could login but that still hasnt happened and its been like 3 weeks.
I'd like to be able to post there, I bought a 460 this morning and will need lots of advice as I rebuild it I'm sure.
Old Aug 10, 2008 | 09:36 AM
JesterPgh's Avatar
JesterPgh
It just takes them awhile over there. I forgot I registered there and suddenly got an email one day that I was good to go.
Old Aug 10, 2008 | 12:11 PM
plastikosmd
yea well it has been 6 wks....if you are on there...shoot us the admin email please
Old Aug 10, 2008 | 12:34 PM
JesterPgh's Avatar
JesterPgh
I don't have an admin email addy. You email them from there, and it does it from the site. I posted the question in Chilly's Garage, sorry I can't help more.
Old Aug 10, 2008 | 03:56 PM
plastikosmd
no you cant email them if you cant log on..that is the problem. if there is a logon issue you need to email them..but as stated you cant email without logging on.
if you cant take the time to pm me his email then so be it....i will continue to wait or someone else may be able to fingure out how to cut/paste his email into a pm for me...thank you for your help
Old Aug 10, 2008 | 06:03 PM
JesterPgh's Avatar
JesterPgh
You guys use the same usernames on there as on here? It's not a matter of me not being able to take the time to help you out, I'm doing what I can, so you're welcome. I don't HAVE the email address, and the emails send FROM the site, so I can't get the addy ANYWAYS.
Old Aug 10, 2008 | 06:22 PM
plastikosmd
for me, yep same name. Thank you. If it doesn't work I will have the wife create a login and try to draw attention, thx again
Old Aug 10, 2008 | 06:33 PM
JesterPgh's Avatar
JesterPgh
I sent a PM to Chilly, for both of you. We'll see what happens now. I don't carry much weight anywhere on the net, but it's worth a shot.
Old Aug 10, 2008 | 08:17 PM
JesterPgh's Avatar
JesterPgh
You both have PMs.
Old Aug 13, 2008 | 04:51 AM
SLICK-1's Avatar
SLICK-1
from slick
you guys are both to funny good luck on your for regestration im still trying to edit my profile cant figer out how to get back in it i think im ready to pms it lol
Old Aug 13, 2008 | 07:22 AM
plastikosmd
well I am in...phew...all thanks to Jester, for me..the profile part..first log in then click on profile under the "thank the lord for the big block ford" heading..that should get you in
Old Aug 14, 2008 | 04:35 PM
Baba's Avatar
Baba
I have a 1993 F-250HD 4x4 supercab 7.5L V-8 Electronic 4-SpeedAuto.Trans. The Truck has 46000 miles. Work was done on the Trans. at mileage 40847 (10-28-2004).
Under the hood 20A Maxi fuse no. 9 to electronic engine control system, fuel pump relay coil blows on low RPM like the take off from stop light while towing a 25' light trailer, and after replacing maxi fuse no.9 the truck will start immediately. Why does this happen and what should I do to fix this problem? Nobody seems to know how to fix it. thank you, Baba
Old Aug 14, 2008 | 11:52 PM
lewislynn's Avatar
lewislynn
You need to ask your question by posting it on a new thread or a thread with the same subject...This is probably the wrong thread to get an answer.
Old Aug 14, 2008 | 11:58 PM
150ford's Avatar
150ford
Do they have a phone number you could call to get direct contact with them. Sometimes the only way to contact them. Any good site will have that. If not then its probably doomed in time. Why have a site if its not run right. Run it right or not at all. That crap has been going on over there for quite some time. Id say new people should be running it. If the current ones cant do it.
