alternator
Old Aug 4, 2008 | 07:57 PM
jwtimme's Avatar
jwtimme
alternator
Does anybody make a bracket for mounting just an alternator for racing applications? I run an electric water pump drive but need an alternator. This weekend I lost two classes in my car because the battery went dead. The charger could not keep up with demand because of the heat, had to let the water pump run a lot to keep the motor cool.
Old Aug 5, 2008 | 07:54 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader
cant you just use a shorter belt to go from the crank to the alt?? or is the WP in the way??
Old Aug 5, 2008 | 03:25 PM
jwtimme's Avatar
jwtimme
I could use a shorter belt If I did not have a motor plate in the way. And I don't have any bracketry at all did not come with the car.
Old Aug 5, 2008 | 04:41 PM
SwOkcOffRoader
well, you would think since i work in a speed shop (HP Racing equipment) I would be able to find something....but, i just went through all of our catalogs, AND i called our supplier... apparently nobody makes brackets for bigblock Fords, for your application....it even puzzled my supplier...he said you will probably have to fab up something, or switch to a rear motor plate with chains on your motor mounts and find a OE unit....sorry i couldnt help....
Old Aug 5, 2008 | 07:36 PM
jwtimme's Avatar
jwtimme
I have been looking for the past couple of days with little luck. I figured with as many people running bbf that I would find something. I'm already running a mid plate but stock motor mounts are out of the question because of the massive headers and 2x3 steel tube frame. I think I'm going to buy a sbc mount, attach that to the motor plate then build a spacer to go between the dampaner and some pully probably a bbc, what ever I can get to fit the crank.
Old Aug 6, 2008 | 05:31 PM
greenhighboy's Avatar
greenhighboy
Check out 460ford.com There are alot of pics there of cars with motor plates and alt. brackets.
72CC428
Sep 26, 2016 05:50 PM
beartracks
Jun 14, 2016 01:46 PM
V8orBUST
May 26, 2014 02:43 PM
parkland
Dec 21, 2013 12:45 PM
quakerj
Aug 28, 2013 05:57 PM
