Pushrod length checking
Old Aug 3, 2008 | 03:32 PM
v8xploder's Avatar
v8xploder
So i have an adjustable length push rod checker, and Im setting up my 460/532. I marked the valve stem tip completely black with a sharpie and after a couple tries I got my wear pattern dead center of the valve stem. I am using roller rockers, is there anything else I need to do or check before I get them measured at my machine shop and ordered? Thanks
Old Aug 5, 2008 | 11:44 AM
mcdonaldm's Avatar
mcdonaldm
other things to check are;
- check for any interference between the rocker and valves at full lift and at zero lift. should have plenty of clearence at all lift ranges.
- check for clearance between rocker stud and rocker at all lifts. again should be lots of clearance.
- check the pushrod angle compared to the rocker arm seat. should not be any excessive angles at all lift ranges. more of a concern when using Chev BB rockers in the 460 than when using proper Ford rocker arms (the Chev uses a different cup angle than the Ford. lots of companies use the Chev rocker in Ford app as they both use 7/16" studs and the chev is 1.7 ratio while the Ford are 1.73)
that are the basic things to check.
Rgds
mike
88n94
Jul 29, 2016 09:25 AM
qman
Dec 8, 2014 11:56 AM
GW09F350
Jul 2, 2014 07:31 PM
Barrie guy
6.7L Power Stroke Diesel
May 1, 2012 12:33 AM
KonaGrown
Mar 3, 2012 11:05 AM
