Opps.timing set
Old Aug 9, 2008 | 03:41 PM
460me's Avatar
460me
Opps.timing set
I put this cam:
CraneCams
in with a later(72-8?) timing set.Now after about 3500 miles it starting to load up at idle and foul the plugs.No other problems.
ported 79 heads , Edel-performer intake /600 cfm headers-2.5 exhaust
The only thing I didn't replace is the distributor . This truck is a 79 F250 460-c6 Trailer Special.
Any help here?
Thanks
Old Aug 9, 2008 | 04:48 PM
Bear 45/70's Avatar
Bear 45/70
Get a 1971 and earlier timing set and get rid of the 4° retarded cam timing to help throttle response and horsepower.
Old Aug 11, 2008 | 05:07 PM
mcdonaldm's Avatar
mcdonaldm
also get rid of that 600cfm carb. with those mods and cam, you need at least a 750cfm carb for that engine to breathe. the 600cfm is great carb for a 302 or a 351, but not a 460. you will notice a huge difference by swapping out that carb for something bigger.
rgds
Mike
Old Aug 11, 2008 | 06:01 PM
Bear 45/70's Avatar
Bear 45/70
rgds
Mike
What cam? He says nothing about a cam. So you are wrong about the 750 carb. You are also wrong about the 600 being only good for small blocks. You are an overcarburator, very bad for street, mileage and towing. The 600 is great for a stock and/or tow rig. I would replace the stock 600 Holley 4180 emissions carb with a non-emissions Holly 600 if you haven't already. I did just that and with a personally twicked Holley List 1850, 600CFM vacuum secondary carb, my mileage was up close to 1.5 mpg and towing ability increase 2 fold.
Old Aug 11, 2008 | 09:12 PM
460me's Avatar
460me
Read it again,
This cam:
CraneCams
I been having to retard the timing to get it to start.But it will only retard so much
600 is fine for this set up
Old Aug 11, 2008 | 09:22 PM
Bear 45/70's Avatar
Bear 45/70
Originally Posted by 460me
Read it again,
This cam:
CraneCams
Missed that, but a 750 is way to much for a 5000 rpm rev limit. A 650 would be better. For a street truck with any towing in it's future the 600 would still be a better choice as it will improve fuel economy and low end throttle response. Just how often would this engine ever see max revs?
Old Aug 11, 2008 | 09:29 PM
460me's Avatar
460me
Anyways.got new plugs,distributor and a 70 timing set.Time to get busy.
Never,maybe 4 -4500 just for funzie
Old Aug 11, 2008 | 09:40 PM
Bear 45/70's Avatar
Bear 45/70
Then a 600 CFM is far and away the best choice.
Old Aug 17, 2008 | 10:24 AM
460me's Avatar
460me
I put it all back together and all I can say is WOW.What a big difference,I sure that the 30 year old dizzy had something to do with the way it was running.
jhg_12
Jul 28, 2011 07:02 AM
ceetwarrior
85
Apr 7, 2011 07:59 PM
rusty70f100
Oct 12, 2005 09:59 PM
jvicars4
Jul 13, 2003 07:13 PM
Justin03PSD
Aug 12, 2002 03:49 PM
