Emergency Brake
Old Jul 14, 2000 | 02:31 PM
imca09's Avatar
imca09
Emergency Brake
I have an '88 F-250 4x4 single cab, long wheel-base. My question is, when i go to engage the emergency brake, the pedal only starts to become stiff (start clicking where you hear and feel engagement)when i get nearly to the floor, why is that. I have looked underneath at my emergency brake cable, and when not engaged, it is fairly loose. I have also often wondered if i doesn't stay partially engaged all the time because i can feel a drag. If anyone has any comments or knows if that could be a likely possibility, it would be appreciated.
Daniel
Old Jul 14, 2000 | 05:24 PM
deleontow's Avatar
deleontow
Emergency Brake
Your rear brakes are either worn or need to be adjusted.
Dave
http://a2ztowing.homestead.com/a2ztowing.html
Old Jul 14, 2000 | 06:06 PM
StrangeRanger's Avatar
StrangeRanger
Emergency Brake
Old Jul 14, 2000 | 07:31 PM
DannyP's Avatar
DannyP
Emergency Brake
After checking the condition of your brakes and fixing any problems there, if you still have the problem there is an adjustment on the emergency brake cable, roughly located where the bed meets the cab.
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, T-18 but looking for a ZF. 3.55's.
Old Jul 14, 2000 | 08:30 PM
gino93's Avatar
gino93
Emergency Brake
where do you live? if its in snow country the cable sheathing is rotted not allowing for full realease. suggest replacement of rotted cable?
Old Jul 14, 2000 | 11:05 PM
PAUL_2's Avatar
PAUL_2
Emergency Brake
More than likely its as Dave said .... worn or out of adjustment rear brake shoes .
Paul
b4hntn
1978 - 1996 Big Bronco
Dec 14, 2013 10:24 AM
Waff78
1997 - 2003 F150
Dec 31, 2008 01:18 PM
RoyalFord
1997 - 2003 F150
Mar 2, 2008 02:23 PM
briandrex
Nov 25, 2007 10:33 AM
jasonr2210
Mar 12, 2007 11:51 AM
