More A/C Problems
Old Jul 12, 2000 | 07:41 PM
cpgorman's Avatar
cpgorman
More A/C Problems
I found a compressor for my 86 F-150/I-6, but when I wen to put it in it didn't fit. Apparently the motor has been replaced by an I-6 from a different model year.
Does anyone know where the codes are on the block so that I can figure out what year this motor is?
Also, does anyone know if there were any changes to the locations where these brackets mount to the block? The bracket I have is nearly the same except it has nuts welded to the inside. The 86 compressor also has threads in the four lower mounts.
Old Jul 12, 2000 | 11:45 PM
PAUL_2's Avatar
PAUL_2
More A/C Problems
Let me ask where you got the compressor that you want to install ? If its a junkyard or used compressor , you may just be reinstalling a new problem . Ford used a few different compressors that mount or use different brackets but look similar . I think the key to your problem is buying the same compressor as you have now . See what model you have now ...IE: FS 6 , FX 15 etc .
Paul
Old Jul 16, 2000 | 07:40 PM
cpgorman's Avatar
cpgorman
More A/C Problems
>to install ? If its
>, you may just be
>. I think the key
>have now . See what
>FS 6 , FX 15
>etc .
>Paul
My truck did not have a compressor when I bought it. I got the compressor from a junkyard. It is a FS-6 out of a 87 F-150. I went to Auozone and looked at what they say is the correct one, and it looks the same as the used compressor.
I think that I may have found a bracket from an '82 F-150. We'll have to wait and see if that fits any better.
Old Jul 17, 2000 | 08:59 AM
slikness's Avatar
slikness
More A/C Problems
