Part beside Coil
Old Jul 12, 2000 | 12:32 AM
Guy's Avatar
Guy
Part beside Coil
There is a little cylinder bolted to the coil. It's about 1 3/8" long by 5/8" diameter with one wire coming out and plugging to one of the three wires that are near the coil, the other two go to the coil. What is this little cylinder for because the wire is starting to corrode and maybe I should replace it.
Thanks
Guy
'92 F150 XL 4x4, 5.0L AOD, Headers, K&N Air Filter, 3.55 Gears, 31x10.5x15 Tires.
Old Jul 12, 2000 | 08:59 AM
RGAZ's Avatar
RGAZ
Part beside Coil
A CONDENSOR, but in actuality it is a capacitor.
It was added to all cars and trucks inductive ignition system to reduce noise on the electrical system. If you have a bad one then the radio will while in tune with the engine rpm. If you are worried about it, i'm sure it is less than $5 at Autozone.
Later.
Randy
Old Jul 12, 2000 | 04:13 PM
samisage's Avatar
samisage
Part beside Coil
Old Jul 12, 2000 | 04:41 PM
Guy's Avatar
Guy
Part beside Coil
Thanks RGAZ, my radio is buzzing like a chain saw. Think i'll change it
Guy
