Read fault codes, need advice
Old Jul 16, 2000 | 05:18 PM
kwebb's Avatar
kwebb
I just read the fault codes on my '91 150 5.8l auto XLT 4x4 Ext cab. I've only run the ingnition on, truck not running test so far. I got a 67...Neutral Drive switch system fault/PNP switch open. Also got a 334...EGR closed valve voltage higher than expected.
Here's my question;What problems or potential problem are these fault codes causing me?
Question 2 what are the top two or three power/mileage ehancing projects for this truck?
Thanks, Kurtis
Old Jul 16, 2000 | 07:21 PM
slowtarget's Avatar
slowtarget
The list that I have for 67 is
Park Neutral Position Switch circuit open - A/C on.
Did you do the test with the Air switch on??
The 334 is listed as EVP sensor is/was high. Is this a hard fault or just in memory. When you flash the codes you get 2 sets of codes. The first is hard faults, meaning that the sensor is reading high now. The second is a memory fault, meaning that it was high. This could be a bad connection to a sensor that does read some of the time.
Old Jul 16, 2000 | 07:40 PM
cpgorman's Avatar
cpgorman
