Rear Gear Swap
Old Aug 12, 2000 | 08:32 PM
Johns331's Avatar
Johns331
Rear Gear Swap
I want to change the rear gears in my '95 F150. It currently has a 3.27 and I want to install a 3.55. My question is. Since the transmission is controlled by the computer and the speed sensor, will I have any problems with the transmission shifting? Thanks!
Old Aug 14, 2000 | 09:58 AM
frankenstein's Avatar
frankenstein
Rear Gear Swap
No...the speed sensor is run off of the Pulse timing disk in the rear end, this also controls the anti lock brakes, your shifting is conrtoles by two things most likely, 1 throtel position, 2, output shaft speed,
Hope this helps
Old Aug 14, 2000 | 07:57 PM
bagman150's Avatar
bagman150
Rear Gear Swap
