Modulator Valve
Old Aug 13, 2000 | 11:34 AM
PAUL_2's Avatar
PAUL_2
Modulator Valve
Old Aug 15, 2000 | 06:39 AM
hoppy's Avatar
hoppy
Modulator Valve
I have an 88 F-150 and the vacuum line leading to the modulator valve is full of transmission fluid and i want to replace the valve, can anyone tell me how to identify whether the transmission in the truck is a C-4 or a C-6. I also would like to know of any tips on replacing the valve.
Any information would be quite appreciated.
Hoppy
Old Aug 15, 2000 | 06:53 AM
Nathan's Avatar
Nathan
Modulator Valve
The c4 has a removeable bell housing, where the c6 has a 1 pc case. Replacing the valve is simple, screw out the old, screw in the new.
Nathan
Old Aug 15, 2000 | 07:00 AM
slikness's Avatar
slikness
Modulator Valve
Make sure you get the right valve. There are several with different colored stripes depending on your driving habits and how you want it to shift. Ask when you buy the valve.
Also, you will get quite a bit of fluid out when you pull the valve. If you park downhill and jack up the rear of the vehicle as high as you can, you can minimize the fluid loss. Make sure you use jack stands if you raise the rear.
'82 F150 2WD w/351W (orig 300 I6)
Slik
Old Aug 15, 2000 | 11:11 AM
hoppy's Avatar
hoppy
Modulator Valve
Thanks for the help guys.
Hoppy
