Starter Problem!!
Old Aug 7, 2000 | 06:07 PM
doctor's Avatar
doctor
Starter Problem!!
HELP!! I have a 1986 Ford F150 Pickup w/ 300 6 cylinder. C6 automatic transmission. My starter is no meshing with the flywheel. Both the starter and flywheel have been replaced but still grinds and refuses to start. Any help would be appreciated..thanks
Old Aug 7, 2000 | 10:19 PM
rocky50's Avatar
rocky50
Starter Problem!!
When did you start havin this problem? Why did you have to replace the flywheel? Is the starter gear engaging the flywheel a little to cause grinding?
Sounds like a wrong part, starter or flywheel.
Good luck,
Moe
Old Aug 8, 2000 | 05:37 PM
doctor's Avatar
doctor
Starter Problem!!
I REPLACED FLYWHEEL BECAUSE I THOUGHT IT WAS BAD BOTH PARTS ARE CORRET BUT IT STILL EATS UP THE TEETH ON THE STARTER WHEN I START IT UP
Old Aug 8, 2000 | 10:08 PM
rocky50's Avatar
rocky50
Starter Problem!!
>IT WAS BAD
>I START IT UP
THEN THINK BACK TO WHEN EVERYTHING WORKED PROPERLY AND YOU'LL FIGURE IT OUT. YOU MAY HAVE TO SHIM THE STARTER. I WENT THRU 7 REBUILDS (I COULD HEAR THE FLYWHEEL HIT THE STARTER ON DOWNSHIFTS) AND THEN I BOUGHT A NEW FORD SUPERSTARTER, PROBLEM SOLVED.
Old Aug 9, 2000 | 05:58 PM
doctor's Avatar
doctor
Starter Problem!!
I JUST TALKED TO MY MECHANIC AND HE SAID HE HAD TO PUT A BIGGER BENDIX I THINK IN IT TO MAKE IT WORK RIGHT
Old Aug 9, 2000 | 10:32 PM
rocky50's Avatar
rocky50
Starter Problem!!
> I JUST TALKED TO MY
>HAD TO PUT A BIGGER
WELL DANG! GOOD LUCK.
Old Aug 10, 2000 | 02:44 PM
TLindquist's Avatar
TLindquist
Starter Problem!!
