I am overwhelmed by the number of different radius arm bushing kits available. Can someone shed some light on this? Some are "improved" desings, some add adjustment to caster. I can't decide!
Thanks
Regular rubber (stock design) wears out quicker, but is softer, so you get a little more suspension travel.
Polyurethane are harder, so they last longer, but they don't flex quite as well.
I have heard bad things about the caster adjusting bushings. The offset hole either doesn't sit right, or it doesn't stay put or something. In addition, you would need to have the caster angle measured to know how much adjustment is needed to the caster (if any).
They have been replaced before, I am not sure if it still has rivets or not. Do the new ones come with bolts? I have just ordered a manual to refer to.
Thanks
