power window problems
Old May 16, 2007 | 08:05 PM
togle1's Avatar
togle1
Smile power window problems
Hi all, I have recently purchased a 2000 explorer sport. It has the 4.0 and 5 speed tran., with 137,xxx miles. Everything works and runs well except the power windows ( both driver and pass) and no dome light. I have checked the fuse under the hood and it looks fine. Any suggestions on where to start next?
Old May 16, 2007 | 11:29 PM
aquanaut20's Avatar
aquanaut20
Yes!
Please give details, what is/not happening with the windows
Old May 17, 2007 | 08:44 PM
togle1's Avatar
togle1
windows will not do anything. They won't roll down or up and there doesn't seem to be any noise from the motor trying to work ( the window motor)
Old May 17, 2007 | 08:49 PM
steve(ill)'s Avatar
steve(ill)
bad switch or no power to drivers door control panel ?
Old May 17, 2007 | 09:44 PM
aquanaut20's Avatar
aquanaut20
The main power wire in the door bellows is broken, probably find others ready to go, I add/solder a 2" piece to relieve the stress
Old May 20, 2007 | 01:49 PM
aquanaut20's Avatar
aquanaut20
Did you get this fixed??
What was the problem??
Old May 23, 2007 | 10:56 PM
togle1's Avatar
togle1
not fixed yet
I have checked the wires and none are broken. I seem to have power to the switch, but still neither passenger or driver winows will roll down. The passenger controls give the same results. I am thinking that the motors are bad, but hate to shell out the money for them and be wrong.
