01 sport trac throwing code, need help
Old May 21, 2007 | 03:22 PM
psu927's Avatar
psu927
p1404 i believe is the code. Truck has 215k miles on it. Problem with the truck is, no power. Hardly any power. Plugs and wires recently replaced and that fixed a problem we were having not enough power to climbn a hill) but I am not sure when this problem started. (parents vehicle). So when you accelerate, very little power but enough to drive it around. If you punch it from a stop, it tops out at 4500 rpm and then won't shift. And for the record, I can hear a clicking nose that sounds tranny related. (really fast clicking.) and idea's?
Old May 21, 2007 | 05:58 PM
chaseface84's Avatar
chaseface84
Heres what i found dont know if its your problem but it doesnt hurt to check it out
P1404 Exhaust Gas Recirculation (EGR) Valve Pintel Stuck Open
Old May 22, 2007 | 05:02 AM
psu927's Avatar
psu927
would that be causing the problem I'm having? Anyone know what I can do to check it?
Old May 23, 2007 | 07:08 PM
psu927's Avatar
psu927
bump, need some help here if any knows
Old May 23, 2007 | 08:16 PM
chaseface84
are you sure that is the code, cause i dont think they use that code for an 01 sport trac
Old May 24, 2007 | 10:54 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
psu remove your EGR valve and check it for carbon build-up... sometimes a chunk of carbon can get wedged in there and hold it open a bit. Clean it as good as you can, and work the pintle up and down manually.. make sure it works smoothly. If it's so bad you can't move it, buy a new EGR valve.
And yes this can cause a bit of a misfire and lack of power.
Good luck
liquidlounge
Dec 3, 2014 04:39 AM
ford country boy
Mar 1, 2014 12:03 PM
lowrider50
2004 - 2008 F150
Apr 24, 2013 05:42 PM
simply_peter
Jun 18, 2009 10:02 AM
tdanco
1983 - 2012 Ranger & B-Series
Oct 6, 2003 04:03 PM
